Re: Getting tires back on tractor
Posted by Dean Olson on February 18, 2010 at 14:14:10 from (76.200.92.156):
In Reply to: Re: Getting tires back on tractor posted by sflem849 on February 18, 2010 at 13:51:06:
I learned that along time ago. Lean the tire up against the hub and jack the tractor up. I used to be able to handle 13.6 x38" loaded by myself. I will always remove the tire from the hub. I have left the weights on the hub and used the same technique roll the hub and jack the tractor. I never was man enought to handle the assembled hub,rim and tire by myself. If you have to handle the whole assembly, such as when turning the dish inside, I used help and a loader tractor.
