Re: Farmall Hydraulics Fluid Capacity
Posted by Janicholson on February 18, 2010 at 20:26:59 from (64.61.211.126):
In Reply to: Farmall Hydraulics Fluid Capacity posted by mrf-engines on February 18, 2010 at 17:11:14:
If it has the Liftall Belly pump for a reservoir, it will be 6 gallons. Volume of cylinders equals A=pi*radius squared times stroke. In most cases on a hitch 6 gallons will be plenty. If it is all external, 5 or 6 gallons is good, 8 gallons if also using a loader. The use of the non-pressure ends of the cylinders for added volume of reservoir is a good idea. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
