Re: Farmall Hydraulics Fluid Capacity
Posted by williamf on February 18, 2010 at 22:27:55 from (141.129.1.98):
In Reply to: Farmall Hydraulics Fluid Capacity posted by mkirsch on February 18, 2010 at 17:11:14:
Janicholson said: (quoted from post at 21:26:59 02/18/10) If it has the Liftall Belly pump for a reservoir, it will be 6 gallons. Volume of cylinders equals A=pi*radius squared times stroke. In most cases on a hitch 6 gallons will be plenty. If it is all external, 5 or 6 gallons is good, 8 gallons if also using a loader. The use of the non-pressure ends of the cylinders for added volume of reservoir is a good idea. JimN
Jim, didn't you mean quarts? On the reservoir part, I mean.
Wm
This post was edited by williamf at 22:33:17 02/18/10.
