Re: Farmall engine adapter
Posted by sflem849 on February 19, 2010 at 05:29:55 from (69.197.84.192):
In Reply to: Farmall engine adapter posted by Dave H (MI) on February 13, 2010 at 09:52:00:
Janicholson said: (quoted from post at 16:56:54 02/13/10) ...454 is a Chevy displacement. Olds is 455 (and not at all similar) ...
That is the first thing I thought as well :D not to mention...ROCKET BLOCK!!!
Kevin's Machine and Welding on Carvers Rock Rd in Avalon, WI can make one for you. Just north of Clinton, WI. He is pretty good with that stuff. I never heard of a kit for doing it esp with a 454/455. Usually they are cheap, available motors like 350/351. Kevin could get you going on the plate to go to the trans and the motor mounts.
