Re: Farmall H rear end leaking
Posted by Zachary Hoyt on February 19, 2010 at 06:56:21 from (74.33.219.38):
In Reply to: Farmall H rear end leaking posted by Joe A. on February 19, 2010 at 04:46:13:
I just changed the countershaft seals on my H, and I put in two new ones to fill the space taken by the old one. The belly pump was out anyway. I went on the archives and found advice to put the tractor in 5th gear and block the wheels to unscrew the nut on the end of the countershaft. I used the belly pump drive coupling as a way to engage the nut. I just took out the cotter pin that holds the collar and put in a grade 8 allen key bolt and then used an 18" crescent wrench tightened around the collar. The bolt head stuck out far enough to keep the wrench from just spinning on the collar. It was pretty easy to do, and then it was all smooth sailing from there on out. I hope that is helpful.
Zach
