Posted by sflem849 on February 19, 2010 at 13:29:50 from (69.197.84.192):
In Reply to: Dual Fuel Farmall H posted by john *.?-!.* cub owner on February 18, 2010 at 11:26:58:
Russell grieff said: (quoted from post at 11:24:05 02/19/10) hi i was not aware of that and i got a bunch of old parts books dateing bake to 1938 and i can not find that any where any info you got would be great thanks
I think he is incorrect.
I finally got the ambition to look it up. The parts diagram does not show a break for that item, but does show a break when they upgraded the bowl from metal to glass. Here are your p/n's
14 1 49653DC STRAINER/Retired FUEL STRAINER WITH 2 NUTS, 29899D (S/N 501 to 50865)
14 1 358245R91 STRAINER ASSY. FUEL STRAINER WITH NUT, 29899D (Will work for 51066DCX) (Gasoline)
14 1 58361DB STRAINER ASSY. FUEL STRAINER WITH 2 NUTS, 29899D (Distillate or kerosene) (S/N 50866 up)
14 1 58372DX STRAINER/Retired FUEL STRAINER WITH 2 NUTS, 29899D (Metal bowl type) (Distillate or kerosene) (Field change only) (S/N 501 to 50865)
Here is what the book says for the little tank. He may be on to something since they switched to a different needle valve, but there is only a needle valve, no strainer, from day 501.
17 1 49654DX FUEL TANK NEEDLE VALVE WITH NUT 29899D (Distillate or kerosene) (S/N 501 to 15743)
17 1 55474DX VALVE GASOLINE OR FUEL TANK NEEDLE VALVE 55474D WITH NUT, 29899D (Distillate or kerosene) (S/N 15744 up)
17 1 55474D GASOLINE OR FUEL TANK NEEDLE VALVE (Distillate or kerosene) (S/N 15744 up)
The fuel lines all say from gas tank to stainer as well. The upgrade to overcome vapor lock from corn picker is peculiar.
18 1 58367DAX FUEL PIPE - gasoline tank to strainer with 2 nuts, 29899D (Distillate or kerosene) (S/N 50866 up)
1 222-503 TUBE NUT FUEL TANK NEEDLE VALVE COUPLING NUT (Distillate or kerosene)
1 52643DX PIPE/Retired FUEL PIPE - fuel tank to strainer with 2 nuts, 29899D (Distillate or kerosene) (S/N 501 to 15743)
1 55475DX FUEL PIPE - fuel tank to strainer with 2 nuts, 29899D (Distillate or kerosene) (S/N 15744 to 50865)
1 58368D GASOLINE TANK, fuel tank, pipes and strainer field change package (To overcome vapor lock when tractor is equipped with corn picker) (Distillate or kerosene) (S
1 58369D GASOLINE TANK, pipes and strainer field change package (To overcome vapor lock when tractor is equipped with corn picker) (Distillate or kerosene) (s/N 15744 to
Here is the distallate to carb line.
15 1 52644DX FUEL PIPE - strainer to carburetor with 2 nuts, 29899D (Distillate or kerosene) (S/N 501 to 50865)
15 1 56451DX FUEL PIPE - strainer to carburetor with 2 nuts, 29899D (Gasoline)
15 1 58366DX FUEL PIPE - strainer to carburetor with 2 nuts, 29899D (Distillate or kerosene) (S/N 50866 up)
This post was edited by sflem849 at 13:42:27 02/19/10 2 times.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
