Re: Running hydraulic pump off M belt pulley
Posted by Wardner on February 19, 2010 at 20:38:07 from (4.154.241.158):
In Reply to: Re: Running hydraulic pump off M belt pulley posted by glennster on February 19, 2010 at 20:03:41:
Glennster is right about the 540 Prince pump. The same pump is sold as a 1000 RPM pump by changing the splines. Yup, you get double the volume too.
If you have a lathe and welder you could take an over-riding PTO adaptor and cut off most of the ratchet part. Weld it to a disc with four or eight holes. True it up in the lathe. Cut a counter bore on both sides of the disc to obtain concentricity. Attach a torque arm to pump body so that it doesn't rotate.
Or you could bore out the belt pulley shaft. Weld in a 1-3/8 six spline ID adaptor. Get a PTO shaft extension and stuff it in the adaptor.
All this PTO stuff is in the Hub City on-line catalog
