Pump should not be hot unless the hydraulics are working really hard. If the engine is laboring and the pump is hot, then that indicates that something is stopped up, or the system needs adjustment. The stops on the system are supposed to be set so that when the rockshaft arms reach the set point with the levers, that the control valve relieves the pressure from the pump. It sounds like the pump is under pressure all the time causing it to overheat. When the system is not active, the pump should only be circulating the fluid without pressure. There are some plugs on the hydraulic manifold where it attaches to the reservoir. You can remove one of those and put in a pressure gage to see what is going on.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
