Re: cub purchase
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by ltf in nc on May 02, 2000 at 08:40:51 from (206.228.214.116):
In Reply to: cub purchase posted by law on May 02, 2000 at 07:38:09:
You should know that if you are going to use the tractor to cut the grass that you should not let the grass get very tall between the mowings as the tractor is not over supplied with horsepower. With the mower set at the height that you are going to mow the front of the mower (leading edge) needs to be lower than the rear (trailing edge) inorder to yield the maximum performance from the underpowered engine. This makes a BIG difference. Good luck with your purchase. I certainly enjoy mine.
Post A Followup
: Re: Re: cub purchase
