Re: 'Nuther question on belt pulleys
Posted by sflem849 on February 20, 2010 at 07:07:59 from (69.197.84.192):
In Reply to: 'Nuther question on belt pulleys posted by Farmer_Adam on February 19, 2010 at 19:09:00:
Wardner said: (quoted from post at 20:34:01 02/19/10) Pulley size makes no difference to RPM. It is only a factor when connecting a load to pulley drive.
H RPM is 1121 no load
M RPM is 998 no load
Info from I&T shop Manual.
Good point. The center will spin the same amount, but the belt would move faster based on what pulley you are using. Duh
