Re: Pulley gear box WD-9
Posted by Wardner on February 20, 2010 at 07:54:38 from (4.154.243.33):
In Reply to: Pulley gear box WD-9 posted by plow hand on February 20, 2010 at 07:08:01:
It is splashed lubed from the transmission. There is, however, a shelf in the housing that collects oil. It should be filled with a quart of oil if you are immediately using the belt pulley after it has been installed. There is a fill plug on top.
