Re: fuel tank and lines
Posted by D Slater on February 20, 2010 at 12:04:50 from (72.65.158.117):
In Reply to: Re: fuel tank and lines posted by sflem849 on February 20, 2010 at 11:48:11:
Both fuel flows went through bowl. No shut off for big tank at bowl. It was shut off at bottom of big tank with a shut off valve. Bowl valve shut off small gas tank from the flow.
