300 pump
Posted by f826 on February 20, 2010 at 15:41:38 from (174.124.175.165):
i had the steal lines off that run from the pump to resrvoir on the tractor and when i put the lines back on i put oil in the lines so the pump wouldnt start dry when the pump built presser and i move the levers the pump has a little noise what is the cause
