Re: 450 LP head revisited
Posted by Wardner on February 20, 2010 at 17:08:27 from (4.154.244.179):
In Reply to: 450 LP head revisited posted by Blackland Dan on February 20, 2010 at 16:33:15:
FWIW, the manifold looks like the one on my SMTA. I think the 450LP were separate intake and exhaust. Y-shaped on the intake.
Can't see much of the head but it looks like mine.
I suppose you know that 450LP heads are quite valuable. Between $1000 and $1500, maybe higher now. There is a good chance yours was replaced and is now on a pulling tractor. Remove the Behlen and valve cover for confirmation.
