Re: 450 LP head revisited
Posted by D Slater on February 20, 2010 at 18:10:47 from (72.65.158.117):
In Reply to: 450 LP head revisited posted by Blackland Dan on February 20, 2010 at 16:33:15:
Best I can tell in picture thats the latest 400 LP and also the 450 LP head. To be sure the non LP heads of that type will have very little dip between where the cylinder head nuts contact the head on the left side. Almost flat across between head studs. LP will have pockets a lot of crud can collect in. Manifold is a # 8035 DD gasoline type, originaly came on M tractors serial # 294708 and higher along with SM and SMTA tractors. Like Wardner posted the original type was seperated at intake and exaust above carburetor.
