Posted by Jim Becker on February 20, 2010 at 20:00:34 from (173.57.141.22):
In Reply to: Super A head gasket posted by CNKS on February 19, 2010 at 14:59:48:
The parts catalogs had a bunch of editing done over the years. So they aren't always clear or accurate. I think that references to a C-123 or water pump you find in any Super A catalog migrated in from a Super A1. Here is the way I think it went:
All Super As came with a 113 engine, none with a water pump.
All Super A1s came with a 123 engine with a water pump.
Early Farmall Cs came with a 113 engine and no water pump.
A water pump OPTION was added to the Farmall C.
All Super Cs came with a 123 engine with a water pump.
Head gaskets came with smalll or large water passages for without or with a water pump.
They also came with small or large cylinder openings for 3 or 3-1/8 cylinder bores.
Of the 4 possible combinations of sizes, I know at least three were made at one time (Small bore with or without water pump and big bore with water pump).
2 numbers can be found in the current references. 366301R1 with no water pump, 366300R1 with a water pump.
366301R1 superceeded 43353DD and 354896R1. (I have to wonder if this is the fourth combination, big bore no water pump.)
366300R1 superceeded 356313R2.
I know at one point we needed a small bore gasket and the original had been superceeded by a big bore version and the original was no longer available. Can't remember but think it was an engine with a water pump.
The heat sensor was in the inlet elbow on engines without a water pump. It was in the outlet neck on engines with a water pump. The inlet elbows usually weren't drilled and tapped if there was no gage. The water pump engines had a different outlet (room for the thermostat). I don't know if a non-water pump outlet has material enough to drill/tap for a sensor.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
