Re: W6 hydraulics
Posted by mwebersw6 on February 21, 2010 at 01:23:26 from (207.199.193.98):
In Reply to: W6 hydraulics posted by Bigr on February 20, 2010 at 19:43:15:
Hydraulics can be added...you will need a live pump off of an M-450,hoses from pump to reservoir,and a control valve. The original res mounted under the gas tank and had had the bypass mounted directly to it.If you could come up with a good original res and valve,it would be much easier.The parts book should show hose and valve mounting locations.
