Posted by Andrew Z on February 21, 2010 at 05:03:43 from (64.252.113.90):
In Reply to: W6 hydraulics posted by Bigr on February 20, 2010 at 19:43:15:
also to add, if you go with a IH pump you will need the front timing cover off a late M or SM or 400 or 450 for the pump to mount to. If your tractor is newer then late 48 then you most likely already have the late timing cover and are good to go. Also if you have to replace the timing cover change the cam gear off as well to a later one as they are made heavier and not so prone to breakage. Orrrrr if you have an earlier w6 and do not want to go though that then you could look for a M&W live pump for the M/W6 engine. This would be a direct bolt on.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
