Re: sflem849 early H and M fuel lines and me being fos
Posted by TractormanNC on February 21, 2010 at 06:17:51 from (209.42.180.136):
In Reply to: Re: sflem849 early H and M fuel lines and me being fos posted by D Slater on February 20, 2010 at 16:24:37:
Dave,
I can back you up also. I have an early M S/N 11xxx that my grandfather bought new and has been on this farm since new. We never used anything but gas but I can remember when we took the starting tank off. The lines ran as described, from a shutoff under the main tank to the sediment bowl under the gas tank and through the front fuel tank support to the carb. The threaded outlet on the gas tank is 3/8 pipe thread and the threaded outlet on the main tank is 1/4 pipe thread. I can remember Dad taking the sediment bowl to a machine shop to have the inlet rethreaded so it would fit the main tank outlet. The sediment bowl has a plug in one opening and IIRC it was marked "IN" and the one to the carb was marked "OUT". I also have the ORIGINAL owners manual and the parts section shows this as the only setup. Don't know about others or an H but this one came from the factory with the sediment bowl under the starting tank.
