Re: fuel tank and lines
Posted by D Slater on February 21, 2010 at 08:28:32 from (72.65.158.117):
In Reply to: Re: fuel tank and lines posted by sflem849 on February 20, 2010 at 19:27:57:
For distillate and kerosene in the parts books, most times fuel tank means the big tank and gas is small tank. IN the following I will just put BT for big tank and ST for small tank, fl for fuel line.
SN 501 to 15743 used fuel shut off needle valve 49564 in bt. also fl from shut off to strainer under st was 52643.
SN 15744 up used shut off valve # 55474. from 15744 to 50865 it was used in the bt with fl to strainer at st being # 55475. Shut off valve # 55474 was used in ST serial # 50866 up.
SN 501 to 50865 used fl # 52644 from strainer under st to carburetor.
SN 50866 up with strainer under bt used fl # 58366 strainer to carburetor. Used fl # 58367 from shut off valve under ST to strainer.
SN 501 to 50865 used fuel strainer complete # 49653.
SN 50866 up used fuel strainer 58361.
Above is for D&K farmall H tractors. I left the suffix letters off the part numbers because they changed over the years. Also some part numbers changed. With all the numbers I could have made a mistake putting them on.
