Posted by jimb2 on February 21, 2010 at 09:24:53 from (99.240.236.11):
In Reply to: 674 won't start posted by colin buchanan on February 21, 2010 at 08:56:04:
Hi Colin, make sure you have bled all the air out at the bleeder screws on top of the fuel filter(s). With the STOP/START/RUN lever on the START position and throttle 1/2 open and if you have an air compressor gun and clean cloth stick the air gun in the fuel tank filler and seal with a clean cloth and slightly pressurize the fuel tank, now start cranking the engine with the starter. WARNING DO NOT crank the starter for more than 60 seconds, then let it cool for a couple minutes, then crank engine again. IF the above dosen't work then you will have to loosen the nut on one of the lines from the injection pump to the injectors at the rear of the injection pump and then crank engine again.
BECAREFUL when loosening nut on injection line as the Diesel fuel is under 3000 plus psi and can cause serious injury.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
