Re: Farmall 450 wide front end
Posted by MisterT on February 21, 2010 at 12:22:13 from (209.152.78.140):
In Reply to: Farmall 450 wide front end posted by D Slater on February 21, 2010 at 08:57:20:
old said: (quoted from post at 21:02:24 02/21/10) Because I have been there done that and the one I worked on there was almost no way to change it out with out pulling off the grill and hood so you can pull the steering shaft out of course it also may depend on the brand of wide front. but on the tractor in the picture we found it far easier to pull the hood etc off but where going to either way for painting but still worked out to be easier in the long run
third party image
Rich, there is absolutely NO NEED to pull out the steering shaft. ALL of the parts up inside the bolster are exactly the same for a single wheel front, dual wheel tricycle, or a wide front axle.
