Re: Steering Gearbox Cover Bolts Rub Grille on 47 M
Posted by F-Dean on February 21, 2010 at 13:18:46 from (75.204.5.241):
In Reply to: Re: Steering Gearbox Cover Bolts Rub Grille on 47 M posted by keithg on February 21, 2010 at 08:40:55:
Yes, they are related.
By moving the top of the radiator forward, you will (1) stop the grill wear and (2) move the hood forward. This will move the hole in the hood for the air cleaner forward also which should stop the wear into the air cleaner inlet pipe.
Before you lock the radiator in its new position, I suggest that you put the hood on and check the clearance around the air cleaner inlet pipe.
