Re: 706 brakes
Posted by The tractor vet on February 21, 2010 at 16:33:03 from (75.19.124.251):
In Reply to: 706 brakes posted by ratnickwi on February 21, 2010 at 16:17:03:
Well here i am not real sure what your telling me , but even if the axle housing has been off and one side drilled to take oil from the main housing the level would not be that high to have oil Gushing out . So either for some really odd reason it is that over full and here i would pull the check plug to see or it is slinging oil out past the bull pinion seal that bad or the brake piston is leaking that bad . Now if the bull pinion seal is out check for a bad bearing or two on it . Now as for the brakes yea i have seen some really nasty ones on some of the 706's that i have bought . And when redoing them do it all and be done with it , make sure that the adjusters are free and set when you put it back together Install NEW return spring and what ever flavor brake lining you so chose . And install new seals and O/Rings in the brake piston and with a medium grit emery cloth clean all the surfaces where they ride on . .
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
