Re: Farmall M wiring puzzle
Posted by old on February 21, 2010 at 17:27:15 from (4.245.13.139):
In Reply to: Re: Farmall M wiring puzzle posted by baus on February 21, 2010 at 15:50:13:
Well try doing this and see if it starts up. Run a hot wire from the battery to the coil, ignition side that is. If it fires up then you have a missing wire or connection from the ignition switch to the coil or from the ignition switch to the battery
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
