The Face of the bearing touches the clutch fingers when the pedal is pushed in. When the pedal is released (not pushed, and against the tractor platform) the fingers should be between 1/8 and 3/16" away from the fingers. The disk in the clutch must be assembled so that the center cushion springs are toward the rear (away from the flywheel as pointed out by tractorsam). if put in wrong, the fingers will be way too far away from the bearing, and adjustment will not be reasonable. The fingers are usually about mid travel or a little less when the disk is correct. Let us know what you think on this info. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
