Posted by Jim Becker on February 21, 2010 at 18:07:02 from (173.57.141.22):
In Reply to: removing overspray posted by ken marlatt on February 20, 2010 at 23:28:54:
CNKS said: (quoted from post at 17:05:32 02/21/10) I use oven cleaner as a grease remover on tractors . . . At the least it will dull the underlying paint.
It will also eat the serial number plates and any other aluminum off in short order.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
