Re: 450 LP head again
Posted by D Slater on February 22, 2010 at 06:27:21 from (72.65.146.142):
In Reply to: Re: 450 LP head again posted by Blackland Dan on February 21, 2010 at 15:28:51:
Dan they did use the manifold you have on the 450 now on SM LP tractors below serial # 25931 under part # 357049 R91. That part # was just a 8035 DD manifold with a tee fitting already installed. Above that serial # they changed to manifold 358308 R1 or R11 with tee, the same manifold that would be original to a 450.
If you run across a used 358308 check for cracks. Common place is toward engine below the outlet pipe.
Reason IH give for the manifold type change was for more satisfactory performance in high temperatures.
