Re: Farmall engine adapter
Posted by Carnutz on February 22, 2010 at 09:13:06 from (98.240.236.166):
In Reply to: Farmall engine adapter posted by El Toro on February 13, 2010 at 09:52:00:
sflem849 said: (quoted from post at 06:29:55 02/19/10)
Janicholson said: (quoted from post at 16:56:54 02/13/10) ...454 is a Chevy displacement. Olds is 455 (and not at all similar) ...
That is the first thing I thought as well :D not to mention...ROCKET BLOCK!!!
Kevin's Machine and Welding on Carvers Rock Rd in Avalon, WI can make one for you. Just north of Clinton, WI. He is pretty good with that stuff. I never heard of a kit for doing it esp with a 454/455. Usually they are cheap, available motors like 350/351. Kevin could get you going on the plate to go to the trans and the motor mounts.
If the 350 adapter plate is redily available, it should be easy, the bellhousing bolt pattern in the same small to big block, the only difference would be the "ballance" on the flywheel/flexplate. but if the flywheel is available its fairly easy to change the ballance on the flywheel by adding or removing weight in the right spot... just FYI.
