Re: Farmall 706, wide front
Posted by Rtkman706 on February 22, 2010 at 10:20:26 from (75.121.31.70):
In Reply to: Farmall 706, wide front posted by FarmerD5 on February 21, 2010 at 13:27:47:
Good tractor, if it has glow plugs it has the 282 diesel. If so, check for head gasket failure, ie water in the oil or antifreeze leaks. A common problem from what I've read, but still a good engine.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
