Re: Super C flywheel ring gear
Posted by patrick in illinois on February 22, 2010 at 17:00:32 from (206.71.203.155):
In Reply to: Re: Super C flywheel ring gear posted by Jim Becker on February 22, 2010 at 07:16:53:
It was the small flange that broke. looks like the ring gear still has plenty of support; and yes I am installing a new ring gear.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
