Re: Farmall Super C -Noisy hydraulic system
Posted by IHC53 on February 23, 2010 at 06:01:05 from (64.5.77.101):
In Reply to: Farmall Super C -Noisy hydraulic system posted by brumik on February 22, 2010 at 06:59:24:
My "C" had the same thing wrong with it. I tried all the other ideas until a old mechanic told me that the screen would be collapsed on the pressure regulator valve. He was right, that old knowledge is hard to beat. To get at the orifice you will need to remove the cylinder head which is held on with 14 bolts. They will be either 3/8 or 7/16 bolts. Mine had the 7/16 bolts which used a gasket #354354R3 and the orifice-screen #355372R93. This screen-orifice is about 3 inches long and 1/2 in diameter with a vent opening on the threaded end. Gasket was $11.44 and orifice was $77.67. Cured the problems on mine.
