"staying on high pressure" basically means that something is blocking the flow of oil when you're not trying to do anything.
Normally once you let go of the lever, the oil just flows through the center hole of the valves at low pressure. When you pull a valve, it blocks that center hole and redirects the flow into a cylinder. Because the oil is being forced into a confined space, it builds pressure and the cylinder moves.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
