Re: Brake bands on H
Posted by charlie M on February 23, 2010 at 12:10:25 from (70.101.104.228):
In Reply to: Brake bands on H posted by Farmallb on February 23, 2010 at 09:26:57:
You don't have to take the whole tractor apart to fix your oil problem. There is an oil seal behind the brake drum that is easy to fix. If I remember correctly there is a bolt on the end of the drum that comes out and the drum slides off the shaft. The oil seal is right there. If there is oil leaking from the bull gear holder (not sure exactly what that part is called) that requires removing the top and doing a lot of stuff. Most likely though all you need to change in the oil seal.
