Re: Farmall 450 (gas) Water in Oil pan
Posted by old on February 23, 2010 at 12:46:56 from (4.245.6.41):
In Reply to: Re: Farmall 450 (gas) Water in Oil pan posted by Tony_Idaho on February 23, 2010 at 08:12:27:
Nope anti freeze will not mix like that and that is why I answer you the way I did so as to maybe male it clearer as to what your problem probably was
