Thanks for the heads up. I am not interested in so much originality, just functionality. Will the gasoline manifold be a problem in any way?
I never new about the distillate. What is is it? The manifold does have parts froze up on it. Does the gas manifold affect anything else? Will the carburetor mount up properly? Will any adjustments need to be made to the fuel system? thanks dave
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
