Dave, the distillate manifold was used for dual fuel tractors, ie. could run on Gas or distillate (or kerosene). They have a chamber with a butterfly valve that redirect exhaust gasses through the manifold to heat it up to help vaporize the distillate or Kerosene.
The distillate or gasoline manifolds are totally interchangable. If you happen to have a distillate carb, if you are looking for optimal performance on gas, you will want to change out the jets, BUT THAT IS NOT REQUIRED.
Depending upon the condition of your existing manifold, that should decide whether you spend $75 for the replacement part, or just buy a new gas manifold.
Either way, there are no required modifications to interchange those manifolds.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
