Re: MD Nozzle Body Retainer Removal
Posted by D Slater on February 23, 2010 at 19:03:19 from (71.164.32.3):
In Reply to: MD Nozzle Body Retainer Removal posted by sflem849 on February 23, 2010 at 18:06:11:
IH had a special puller, some come out hard. Not saying this is the best way but the way I remove the hard ones is, with a small 5/8 or 3/4 thick flat plate with slots made on each side to fit the bolt spacing of the nozzle fitting for the fuel line. Weld a long 1/2 inch rod in the center of plate. Used heavy wall pipe doubled 2 sizes togeather for a slider. welded a heavy cap on the other end.
When removing one with the above I clean outside injector and all around it. Then remove the nozzle fitting, then pack a small piece of paper towel in the hole under fitting. Use the two 3/8 bolt holes that retained fitting to bolt plate down flat on body, then go to slide hammering. Some will come out in 1 or 2 hits. Some will wear your arms out.
