Re: Farmall A/B front pulley puller
Posted by Pete7 on February 23, 2010 at 19:06:29 from (72.65.47.188):
In Reply to: Farmall A/B front pulley puller posted by kopeck on February 23, 2010 at 16:04:46:
Used just that item from Harbor Freight last week to take off a pulley on a Farmall 340 ( basically the same engine as on an A,B,C). Worked fine.
Pete
