Re: Farmall H Lift-All seal
Posted by charlie M on February 24, 2010 at 03:39:50 from (70.101.104.228):
In Reply to: Re: Farmall H Lift-All seal posted by russmoore on February 23, 2010 at 19:35:13:
If I recall you have to put a brass rod down the filler hole and lock up the gears, then you can unscrew the fitting. I think it is left hand threads but it has been a long time since I changed mine.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
