Re: super c stops running after 2 min
Posted by Erik Dekeyser on February 24, 2010 at 04:07:08 from (161.216.7.160):
In Reply to: super c stops running after 2 min posted by Steve Ftorek on February 24, 2010 at 03:55:32:
Check and see if there is enough gas at the carb. Take of the fuel line at the carb. and make sure there is fuel there. There is a filter in the little elebow at the carb check to make sure there is no dirt in there. If you dont get enough fuel at the carb. you can take compresed air and blow back into the tank some time there is dirt stuck in the tube on top of the sedement bowl.
