Posted by mkirsch on February 24, 2010 at 05:16:08 from (64.80.108.56):
In Reply to: In need of help posted by Ray in CT on February 23, 2010 at 15:38:25:
The timing is off.
Remove the front spark plug. Have someone slowly turn the engine over with the hand crank while you hold your finger in the spark plug hole.
When you feel air whooshing out, stop. Go to the front pulley and slowly turn the engine until the pointer on the front of the engine lines up with the notch in the pulley.
Follow the front spark plug wire back to the distributor cap. Mark that post on the cap. Remove the cap. If the tang on the rotor is not directly below that post, that's where your problem is.
You've got to figure out why it's that way, and what to do to fix it.
If it's a little off you just need to rotate the distributor a little to line it up.
If it's WAY off, you probably put the wires on the wrong posts.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
