Re: Farmall H Lift-All seal
Posted by Ed Hotaling on February 24, 2010 at 06:30:36 from (69.204.170.52):
In Reply to: Farmall H Lift-All seal posted by RussMoore on February 23, 2010 at 19:15:23:
I did mine last year. You will have to remove the Lift-all unit from the tractor, remove the pump from the reservoir and insert a piece of flat stock to hold the gears while you unscrew the coupler from the shaft. At that point, the seal is easy to get at.
While it is a lot of work, it also gives you the opportunity to clean out the reservoir. Mine was full of milky muck from too many years of moisture and no fluid changes.
If you need more details on what's involved, just shoot me an email.
