Cub clutch
Posted by Christopher Schmitt in Ct on February 24, 2010 at 10:34:02 from (24.151.70.128):
Hi all, I am new to this board. I have split my cub to fix the clutch (it was dragging). I have a rebuilt pressure plate that I bought years ago but never installed. When I compare it to the one on the tractor, they look identical, however the actuating fingers are about an inch higher than the one on the tractor now. The repair book I have lists several possible pressure plates used, but, I have no idea which one I have now. Does anyone have any advise about this? What should the distance from the flywheel surface to the fingers be? Many thanks in advance. Chris in CT
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
