Re: farmall md oil leak
Posted by jim warehime on February 24, 2010 at 15:26:59 from (72.81.200.69):
In Reply to: Re: farmall md oil leak posted by Janicholson on February 24, 2010 at 15:16:28:
thanks for the tip,also the tractor seems very smokey specially at idle though mid rpms any ideas?
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
