Posted by CNKS on February 24, 2010 at 18:00:01 from (216.144.104.128):
In Reply to: 3 PT Hitch posted by Kevin in MI on February 24, 2010 at 03:36:29:
You can run a line from the 2 front outlets on the belly pump and run one to each cylinder or use any one of the three and tee it into the 2 cylinders -- that's all there is to it. If you happen to have the "Christmas tree" remote valve, you can use that and have 2-way hydraulics.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
