Re: 47 H oil seals
Posted by Theman on February 25, 2010 at 05:10:14 from (65.198.133.254):
In Reply to: 47 H oil seals posted by jim warehime on February 24, 2010 at 20:13:57:
What worked for me was to use a small 2-jaw puller. It was disassembled to work the jaws in between the shaft and seal then re-assembled to pull on the seal. They came right out. Another method is to use "cutting screws" driven in the side of the old seal in 3 or 4 places. You can pry them out by the screw heads. The problem with this method is that it makes small chips that can end up where you don't want them.
Original seals will have a double thickness - a seal and felt dust shield. The replacements will be considerably thinner and only contain a lip seal. Some folks install just one, yet others put 2 seals with light grease smeared between them. If the new lip seal is not in the groove made by the original, one should be sufficient.
If the above methods fail, follow the procedure given by The Tractor Vet posted a few days back.
