Re: farmalll 400 serial number
Posted by D Slater on February 25, 2010 at 09:34:57 from (72.65.155.189):
In Reply to: Re: farmalll 400 serial number posted by CNKS on February 25, 2010 at 08:46:21:
Post could be understood 2 different ways, tag or engine numbers. Poster stated the D was after the engine serial #. That would be a non diesel engine originaly equiped with higher compression pistons to compensate for altitudes around 5000 ft. above sea level. D on diesel engines is before the engine size D264 then engine serial # following. On the serial tag the diesel D was stamped on a different line than the serial #.
If a gas tractor has a D on the tag, its following the serial # on the same line and could be bordered with other letters.
