Re: Farmall M Update
Posted by Pat-CT on February 26, 2010 at 14:25:50 from (137.36.225.229):
In Reply to: Farmall M Update posted by Ray in CT on February 26, 2010 at 12:02:53:
Check to make sure #2 and #3 wire dont have any crapon any of the wire ends also make sure the spark plugs are good. Also pop the cap on the dist and make sure thats all clean and everything is making contact
