Re: Priming oil pump on freshly rebuilt Farmall A motor
Posted by El Toro on February 26, 2010 at 15:10:07 from (74.103.74.58):
In Reply to: Priming oil pump on freshly rebuilt Farmall A motor posted by redFarmallboy on February 26, 2010 at 05:14:26:
If you have the pump off set it in a clean container oil and spin the drive gear until oil
is discharged. Then install the pump. Hal
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
